07-16-2021
08:56
04:56
07-16-2021
08:56
04:56
Welcome, @Bernettj. It's good to see you here in the forums.
Thanks for bringing this to our attention. Just to confirm, do you refer to the mindfulness sessions in the Discover section of the Fitbit app? Or did you use the EDA Scan app on your Sense to track a Quick Scan or Guided Session? After completing either session, were you prompt to log the mindfulness session? Also, what is the model of your phone?
In the meantime, let's give a try to the following steps:
Hope this helps.
14:41
04:57
01-31-2023
14:41
04:57
Hi there, @Klimberg.
I'm sorry for this inconvenience and thanks for trying the steps suggested above. I went ahead to check your details and it seems you already have a case created with our Support team. Your case is in good hands and I'm sure they'll continue helping you, so please keep an open communication with them.
Best AnswerI'm having the same problem. It's really frustrating to pay extra and have a subscription only for some of the features I use the most to just never work. I see you noted that someone would reply from the support team, but that was nearly 4 months ago.
