02-06-2024
10:39
06:00
02-06-2024
10:39
06:00
Is Fitbit ever going to fix the bug, glitch, whatever, on the sleep tracker
Best Answer02-22-2024 05:39
02-22-2024 05:39
Sleep data is either inaccurate, saying I only slept 1-3 hours, or missing completely
02-08-2024 02:08
02-08-2024 02:08
Hi @SunsetRunner - as this is most likely a problem with the new Fitbit App not syncing properly - after you have synced a few times successfully. swipe the watch face left and tap on the Today app and tap on the sleep tile and see if there is more information there. - if so it would confirm it is a Fitbit App problem, which may get fixed eventually.
If the Sleep tile is missing scroll to the bottom to add it.
Best Answer02-08-2024 06:04
02-08-2024 06:04
Hi there, @SunsetRunner. Thanks for stopping by in the Fitbit Community Forums. It's sad to hear that your Sense is having issues to track your sleep data. We're here to help. @Guy_ I appreciate your input!
To better assist you, would you mind sharing with us what the issue is exactly with your sleep? What sleep details are you missing specifically? In the meantime, I'd recommend checking this help article Why don't I see sleep stages today?
Looking forward to hearing from you.
Best Answer02-08-2024 19:50
02-08-2024 19:50
@SunsetRunner - btw if you are not getting any sleep data did you check that the watch is showing a heart rate, if not it cannot measure sleep and is a sign of a watch fault.
02-22-2024 05:39
03-19-2024 08:47
03-19-2024 08:47
I’ve tried every tip, suggestion and possible solution, but still not getting anything near accurate sleep data. Is it me, my watch, the app or Fitbit.com?
03-20-2024 04:46
03-20-2024 04:46
I don't think it is you. My doesn't work either. I get the amount of sleep but not sleep stages. I like to benchmark and am not able to. I too have tried everything suggested by Fitbit but I just Sense isn't a very good version.
