11-14-2022
01:03
11:16
11-14-2022
01:03
11:16
Hi. When I first set up my new Sense a few weeks ago the Sleep Score worked great for the first 6 nights and on the 7th it didn't. Then it worked great for the following 4 nights and stopped for 2 nights. Then it worked for the next 2 nights, and since then has not given me a sleep score at all. Yes I get the basics, but not the in-depth information. I have gone through all the posts on the subject I can find, I have a good strap, not too tight or loose, I have tried different position on my left wrist, and no change. With the slow decline of the reading out puts and no changes from me, is this a sign of a problem with my sense? Should I return it for a replacement?
Hello there, @Myeika. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Sense before reaching out.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that in mind, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
Hope this helps.
@Myeika Awesome! I'm glad to hear you managed to solve the issue. Thank you so much for sharing the steps that worked for you. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best AnswerHi Myeika, sounds like you have solved your problem. I had a similar problem, where it had worked pretty well (with an occasional failure) and then all of a sudden, I failed to get sleep scores. I did a reset by holding the side buttons for 10 seconds, and Walla, it has been working ever since. If that doesn't work next time, then also try resetting your phone.
Best AnswerHi Myeika, I have had the same problem and by resetting (hold side buttons for 10 seconds until is shuts down) it did start to work again. However, I still
have nights were I get only the simplified score. I have an iPhone and restarting that might have helped. They do suggest wearing it two fingers width above your wrist bone. It is frustrating, but it works most of the time.
Best AnswerI am having similar sleep and ECG problems. I posted about it a couple of weeks ago. I pay for Premium to get this detailed info and it has worked consistently for at least a year. Both sleep stages, HRV and Breathing scores and ECG stopped working at the beginning of Jan
then after a week suddenly started working again for about a week and now it is not again.
i really think it is something in their software and they need a fix. So frustrating!!! I have been a fitbit fan for years but now Google owns it and I am so disappointed in this.
Suddenly my watch has started working correctly for the last few days now. Fingers crossed that it will continue like this!!
Best AnswerI have had enough of this, and have returned my sense. I'm going to look at getting a different fitbit now, hopefully the new one will work better!
Thanks for all your suggestions
Best AnswerHi Jerry.
I actually got a totally different make. It monitors my sleep & heart rate and everything perfectly, plus I don't have to pay for the extra app data 😉
So sad that fitbit let me down!
