07-19-2022
12:05
04:24
07-19-2022
12:05
04:24
How do I go about returning a defective watch, I’ve only had it 6 months and it won’t charge (I even bought a new charger to see if that was the problem). I tried to “chat” with customer service, but it isn’t available. Losing faith in Fitbit. TIA
Best Answer07-20-2022 04:56
07-20-2022 04:56
Thanks for the reply’s! I thoroughly cleaned the contacts on the watch (I did it one other time, to no avail) and it came back to life. Not sure if it was the two charging cables I tried before or not, but as they say “third time is a charm”! The third cable, or the cleaned prong contacts did the trick. I appreciate the help! Again, thank you!
07-19-2022 13:46
07-19-2022 13:46
Hi @Ghac66 you need to work with support to see what's happening and they will guide you through the process. Try the phone feature to get them. Chat is available when someone is around to help you. https://myhelp.fitbit.com/s/support?language=en_US
07-19-2022 14:08
07-19-2022 14:08
Thank you, I’ll try it now!
07-19-2022 20:19
07-19-2022 20:19
Hi @Ghac66 - it may not be a watch problem. If you have properly cleaned it check the charge cable they are often the cause, see cleaning details in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
07-20-2022 04:56
07-20-2022 04:56
