UPDATE: I talked to a representative, and they suggested to clean the back of the sense with rubbing alcohol (which I usually do), but also to clean the contacts on the charger itself, which I never thought of. So I did, and I plugged it back in for at least 30 minutes, and viola it charged, and is back to normal now! Also user Guy_ suggested this link, and it explains everything. How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
My sense is dead. I plugged it in to charge, and checked it later, but it never charged. I can't get it to turn on now, and it doesn't even respond with vibration when I try to reset it. I noticed this has been brought to before, but no one has resolved the issue. Thought I'd see if anyone has figured this out yet.
Hi @Rachie120 - in all probability it is just not charged. See instructions how to resolve it How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
