08-31-2022
11:50
10:29
08-31-2022
11:50
10:29
HI @Jeresh - normally pushing the button [correctly] for a seconds will wake it, if not place it on the charger, that also wakes it [If it is actually charging].
If that doesn't work check How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best AnswerAccording to Fitbit, you can press and hold down the solid state button on your Sense for 10 second if it's frozen. At first, it will look like nothing is happening, but keep holding the button down. After 10 seconds, the Fitbit logo will display, and your watch will restart.
Regards,
J Wick
Best AnswerHi, @Jeresh welcome, the detailed process (based on my experience) for a restart involves squeezing the side button for up to about 20 seconds and releasing it when the logo appears. After about 30 seconds the clock face should be up & running.
If this fails to restart investigate the state of charge as others have suggested (In the Today screen on your phone Fitbit app slide your finger down & release to sync noting the value next to the battery icon in the top right corner) If the device has little or no charge investigate why as suggested by @Guy_
Cheers
Gr4ndp4 | UK
Hi All, well, it finally did come on later that day. I tried everything I could (holding the buttons for a longer time, holding the buttons for shorter times, etc. Didn't have the charger with me, so couldn't do that.). At some point, I did whatever it took. Can't remember what. 🙂 Thanks for all the help.
