08-24-2022
01:54
15:37
LizzyFitbit
08-24-2022
01:54
15:37
LizzyFitbit
As most people are aware "sometimes" the notifications on the Fitbit Sense are unable to be deleted because the notifications are no longer on the phone having been deleted from the phone when the Bluetooth connection between both devices was momently lost!. The only solution is to reboot the Fitbit Sense to erase all "sticky" notifications.. SUGGESTION> Can the next firmware update include under the settings section on the Fitbit Sense device an option to simply delete all notifications rather than a massive reboot sequence.. Does anyone from the development team ever read these suggestions??
Best AnswerHi, @Flynnpollock welcome, you can post here for Feature Suggestions, you might like to check through previous suggestions to see if any closely match yours or merit your vote.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerTo manage notifications: On the clock, swipe up to see your notifications and tap any notification to expand it for more detail. On a notification, swipe right to delete it. To delete all notifications at once, swipe down to the bottom of your notifications and tap Clear All.
Regards,
J Wick
Best AnswerOH Dear.. You didn't read my posting correctly. Of course I know how to delete notifications "however" as I said "sometimes" the Sense and the Phone get out of sync and its impossible to delete the notifications from the Sense,, This actually happens with all Fitbit devices with notification alerts.
