07-08-2024
14:44
10:12
07-08-2024
14:44
10:12
Fitbit sense not switching on
07-08-2024 21:20 - edited 07-08-2024 21:23
Hi @Nino1978 - there can be lots of conditions causing it not to work so first check it is charged, place on charge, and if it does not come on hold the button for 10 seconds.
See also this link if it is still not coming on How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
07-08-2024 22:46
07-08-2024 22:46
Ciao i tried all the tips above but nothing like its dead no vibration nothing there was a procedure to reset to a factory condition that i did before but i do not remember it
07-09-2024 21:10
07-09-2024 21:10
@Nino1978 - unfortunately if the watch responds in no way, it likely needs charging, or has failed completely, in which case a factory reset is not possible.
The best is to charge from a PC, make sure it does not get hot, and if so stop immediately. Note how the PC reacts when you plug it in.
If it connects and disconnects repetitively there is a fault.
Even so leave on charge for 30 minutes then hold the watch button for a full 10 seconds and release and see if the logo appears and for it to start.
07-23-2024 05:05
07-23-2024 05:05
