07-21-2022 05:10
07-21-2022 05:10
I have reset my Fitbit and my skin temp monitor is still not working!
05:46
18:28
07-21-2022
05:46
18:28
Hi @rickarkg - just to be sure this is something that is measured overnight only. You can't get an instant reading and it only shows deviation from a baseline.
Also after syncing it is not immediate as it has to be calculated and downloaded, that being said there can sometimes be issues with the app.
If it is not showing after a few days, try logout of the app, [for android clear the storage cache and force stop it] and login again and check the next day.
If none of that works chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
Best Answer08-20-2022 08:54
08-20-2022 08:54
My skin temp hasn’t worked in 4 nights.
09:07
16:36
08-20-2022
09:07
16:36
Hi @Kokobean07 - you may see it hasn't worked, though try the following
It might not recover past nights information but may work again - it should be noted skin temp is normally recorded every minute and only shows a single calculed value for the night.
Best Answer08-20-2022 12:04
08-20-2022 12:04
Thanks I will try. I’m not sure though clear cache from phone or Fitbit?
Best Answer08-20-2022 12:06
08-20-2022 12:38
08-20-2022 12:38
I have an older iPhone.
Best Answer08-20-2022 12:42
08-20-2022 12:42
@Kokobean07- logout and restarts may be sufficient.
Best Answer08-21-2022 05:46
08-21-2022 05:46
It worked! I have temp this morning. Thank you!
08-21-2022 06:29
08-21-2022 06:29
@Kokobean07- thanks for the feedback
