12-23-2020 05:00
12-23-2020 05:00
fitbit sense showing sleep score greater than 81 however the app is not showing any measurements. This morning a sleep score showed up in the briefly and and went away after re-syncing. Is this a problem with the device, the app or a combination? Is there a solution?
Best Answer01-09-2021 07:28
01-09-2021 07:28
What happens if you clock on the sleep tile in the Fitbit phone app?
Do you see your sleep and is there an associated score?
Best Answer01-09-2021 18:46
01-09-2021 18:46
Best Answer01-09-2021 22:22
01-09-2021 22:22
@Jas_20How was it last night?
One of the nice features of the Sense is it detects your sleep, you need do nothing for it to do this, but just wear it.
In the morning, after it has fully synced, you click on the Sleep tile and it tells you what your sleep patter was with a score.
You can click on the sleep pattern to get a detailed overview of your night.
Hope its working now?
