06-24-2021 19:33
06-24-2021 19:33
As of now there are DND mode and Schedule DND mode.
For DND mode, which have to be manually turned on, and the watch will no longer vibrate when notifications and incoming call reminders are received from your mobile phone. To turn off, have to manually disable the DND mode.
As for Schedule DND, you can customize the time period during which DND mode is automatically turned on or off.
As I'm working shift, the above 2 mode are not very effective for me. I would like to suggest if fitbit would consider to have Smart DND mode which after you fall asleep with the watch, the watch will automatically turn on DND mode and automatically turn off when you wake up.
Best Answer06-24-2021 21:23 - edited 06-27-2021 21:55
What you are asking was available and worked perfectly, until maybe 1 year or so ago. For some unexplained reason the feature has been removed and in my opinion represent a huge regression.
06-27-2021 19:41
06-27-2021 19:41
omg... anyone know why it was removed? 😱
