07-02-2021
08:49
15:13
LizzyFitbit
07-02-2021
08:49
15:13
LizzyFitbit
Could it be,
that SpO2 works ONLY when I have the "SpO2 Signature" face on overnight,
but NOT when I have "SpO2 Waveform" or "SpO2 Active" face overnight? (??)
(Fitbit represantatives, pleas comment ...)
Moderator Edit: Clarified subject and updated label
Hi @pavfer. Welcome on board.
Thanks for sharing these details. This is odd as if the SpO2 Tracker app is installed, your watch should track your SpO2 data regardless of the clock face you're using. Because this isn't the case, are you able to see your SpO2 data in the Today app of the Sense and Health Metrics tile of the Fitbit app? Do you see an error message when using other clock faces?
In the meantime, I'd recommend the following steps:
Hope this helps.
I apologize, no time to experiments at the moment,
I just remained with "SpO2 Signature" and it works each night thereafter.
Some developer could maybe look into implementation of the 3 faces,
and tell, whether the difference in behavior could make some sense,
or it must have been random ...
Hi @pavfer. It's good to see you again.
Thanks for taking the time to review my post. While I'm glad your SpO2 data has been recorded correctly so far, please give a try to the tips suggested above whenever you have time so our team can investigate what may be occurring and work on this situation. Fitbit values every feedback shared in the forums as it helps us to improve our products, so rest assured yours won't be the exception.
Have a good one.
Yesterday I have chosen "SpO2 active" and
and did not touch it over night,
and it it worked,
so it seems to be OK at least in that "workflow".
Conjecture:
Could it be, that that "Couldn't read SpO2" message comes in cases,
when you have switched DURING THE NIGHT
from one of the faces supporting SpO2
(i.e. "SpO2 Signature", "SpO2 Waveform", "SpO2 Active")
to another one?
Hi @pavfer. I hope you're doing well.
Thanks for getting back with detailed information about the clock faces. It's kind of weird as your Sense should track your SpO2 data regardless of the clock face you're using or if it's changed, as long as the SpO2 Tracker app is installed. Because you didn't have be time before, please try the suggestions shared in my post in case you haven't done so to see if your watch tracks this data correctly.
If by any chance you keep getting the "Couldn't read SpO2" message, try swiping to the left and opening the Today app to see if your SpO2 data appears there. Also, confirm, if the SpO2 data appears in the Health Metrics tile of the Fitbit app.
Hope this helps.
