09-29-2020 06:19
09-29-2020 06:19
How do you interpret the red heart beat graph on the standard clock face? I get the steps and the sleep number. Is there a way to change what is graphed? Thanks!
09-30-2020 04:39
09-30-2020 04:39
@JohnC I assume you are referring to the 'Spectrum' clockface. Unlike some other clockfaces, this clockface does not have any settings that can be changed (in the Fitbit app). There are 3 components displayed on the graph - steps, sleep score and current heart rate. If you tap on the clockface it it will scroll through each graph individually. On the overview screen, the 3 graph lines are simply overlayed.
09-30-2020 19:46
09-30-2020 19:46
Thanks. Yes I figured it out. The other two graphs are cumulative, but heart rate is instantaneous.
10-05-2020 06:31 - edited 10-05-2020 06:43
Hi @JohnC - I don't think that they are cumulative. The sleep score is the current score, the heart rate is the current heart rate and the steps is the current total steps for today. Each graph has a scale on the righthand side (100% for sleep and step goal) and the line goes from 0 on the left to value on the scale on the right. The lines of each graph are simply overlayed on the overview screen.
03-26-2022 02:22
03-26-2022 02:22
Can I get this clock face on my Versa 3? What is called in the face store so I can change mine to this one?
03-26-2022 03:16
03-26-2022 03:16
@SunsetRunner I'm sorry, but the Spectrum clock face is only available for the Sense. Spectrum
Laurie | Maryland
03-26-2022 21:11
03-26-2022 21:11
Hi @SunsetRunner - have a look in the Gallery for what you want, there are many good different clock faces..
03-27-2022 15:40 - edited 03-27-2022 15:44
"...there are many good different clock faces."
Absolutely. First thing I did was hunt down a few free clock faces. I then deleted all the shipping ones. They had absolutely no appeal to me. Awful in fact!
The default ones don't do much justice for the Sense out of the box. It should start up with one of the best for numerous obvious reasons. Many users just stick with the default. That's sad.
Reminds me of the shipping default one on the Ionic. Gee, that was bad!
