I cannot get the Sense to come out of the mindfulness session. This has happened twice now in the last week. I just started to use it after a jog and some light yoga. I am sweaty so I am not sure if that is the issue. However after Andrew finishes the mindfulness and I take my hand away from the face, it will not respond to the side button. Any ideas? Last time I tried to wipe it down and then put it on charger and left it. I was try that stain. Seems a silly practice though.
Hi @Vindicator - it may be that moisture is a factor but to be sure try turning the display on and off under normal conditions using the button in case until you are sure to master the knack.
Often a swipe face from left edge to the right will go back [end] and it may work at times when you can't get the button to work. You can try this in the Settings menu click on Display then swipe right a few times till you are back at the clock.
