09-25-2020 01:24 - edited 09-25-2020 01:24
I noticed I need to beat it to wake it up. Tapping lightly won't wake it up, not like it happens with other smartwatches. Maybe they can fix that.
09-25-2020 07:07
09-25-2020 07:07
@SunsetRunner your sense has a touch screen. You want to touch with the same touch used when typing on the phone.
Just do a light touch, any sliding of the finger will be detected as a swipe and will not activate the screen.
09-25-2020 09:15
09-25-2020 09:15
Agree. I can't work out how to wake it up exactly at all. Sometimes I need to touch it 4 or 5 times in quick succession - I have tried all sorts of combinations including just a light touch as suggested below. It's completely sporadic in how to wake it up. I've disabled Quick View. Would really like some help on it!
09-25-2020 09:33
09-25-2020 09:33
Mines the same! Very hit and miss, tried light, double tap, hard tap!
09-25-2020 09:35
09-25-2020 09:35
@Rich_Laue wrote:@SunsetRunner your sense has a touch screen. You want to touch with the same touch used when typing on the phone.
It's the inconsistency that's the issue. In my testing there was one time I tapped 55 times before it worked. Other times it worked first time. I'll rely on Quick View or the button.
09-25-2020 09:56
09-25-2020 09:56
I thought this was an intentional change with the new OS, I read that the only way to "wake" the device is to press the button or to raise the device. reviewers have said as a complaint they can no longer tap to wake, they have to raise their arm or press the button. i just got mine and i'll play around to confirm, although it's plugged in and charging and preliminarily it would appear to be the case. tapping the screen doesn't appear to do anything, i have to press the button.
If this is an intentional design change then we need a feature request to have a setting to allow you to tap to wake if preferred.
09-25-2020 10:03
09-25-2020 10:03
I literally just had to tap it twenty times to get it to wake up. Once it’s awake, if you leave it to go back to sleep, you can then touch it once and it will wake up straight away - it’s when you leave it go a sleep for a longer length of time - that’s when you need to start repeated touch. I even tried a factory reset just now and changed back to the standard watch face and it’s still exactly the same. This is clearly some sort of bug that needs a fix.
09-25-2020 10:05
09-25-2020 10:05
@bobby2478 there's a comment in the manual that says:
"When you set screen wake to automatic , the screen turns
on each time you turn your wrist. When you set screen wake to manual, press the button or
tap the screen to turn on the display. "
I've tried on both automatic and manual and have the same issue.
Best Answer09-25-2020 10:28
09-25-2020 10:28
Just tested this on a Versa 3. It was an issue there too
Best Answer09-25-2020 11:54
09-25-2020 11:54
@SteveH now I see what you mean. I got it charged and setup and sometimes it responds to a tap (single or double), other times it does not. I notice if I first press the button/raise my arm to wake the device, then press the button to turn off, then if I tap the screen it responds right away. If the screen has been off for awhile however (several minutes) and then I tap the screen it seems to not always respond. Has that been your experience as well?
09-26-2020 00:31
09-26-2020 00:31
@bobby2478 I can't say that I have noticed that. It seems pretty random to me
Best Answer09-30-2020 11:46
09-30-2020 11:46
same issue here. (same as the versa 2) i thought they will fix it on the sense but....
Best Answer01-08-2021 20:48
01-08-2021 20:48
Same issue. Works fine after the watch was just on but after 1-2 mins it appears to be I. A deeper sleep and it could take 50 taps on ever part of the screen before it comes on... if it does. Tried tapping the watch band and corners like other suggested. All work fine when watch was recently active but again issue once off for longer time. I may return my watch just for this. Very inconvenient. My index finger is sore from violent taps and thumb from the awkward pressure I need to put to push the “button”. Really wanted Fitbit to work.
