01-18-2021
13:45
08:14
WilsonFitbit
01-18-2021
13:45
08:14
WilsonFitbit
Is this the normal behavior? In the video I don't press the button any time i just flex my wrist. https://youtu.be/y7JmVSief8Y
No, @Rinopopo, it is not normal behavior, but there have been other posts in this forum with users experiencing the same thing. I find the button hard to press, and have never have had it get accidentally pressed, but if you do a search on this forum you will find out such reports.
01-21-2021
06:59
07:51
01-21-2021
06:59
07:51
Hello @Rinopopo Welcome to the Community Forums! @USAF-Larry @Guy_ I appreciate your input!
Please note that contact with water can behave as a button press. In this case as @Guy_ mentioned, please review the button shortcuts and quick settings. How do I navigate my Fitbit device?
Keep me posted.
Best AnswerIt happens to me as well. When I grab a glass out of the cabinet, when I open a door handle, when I put my hand down to push myself up. I liked the button tied to alexa as it was on my versa 2, but I'll be doing something and alexa will start talking to me. Its very annoying and I have decided to send mine back. Hopefully sense 2 and versa 4 go back to a physical button!
03:15
07:51
01-23-2021
03:15
07:51
Hello @Moosetracks It's great to see you around! Thanks for the information!
Are you wearing the Sense too tight? I also suggest to wear it a little bit looser so the button isn't activated when you bend your wrist. In the meantime, I recommend performing a restart to see if that helps or makes a difference. For instructions, please see: How do I restart my Fitbit device?
Let me know how it goes.
