The entire interface where you can change the Fitbit watch face is extremely bad.
Why are there no filters so you can narrow the number of watch faces that would be of interest. Sorry Fitbit - it's just not anywhere near "good enough".
Best AnswerThere is a forum for feature suggestions.
If you post there, perhaps they’ll do something about it and bring it up to your standards.
https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
Hi @SunsetRunner - in the Gallery tile you can click on the search icon and enter criteria you want to search for. It's not great but a help.
However, if you simply click on the clocks or apps tab they are prefiltered by sections, also not great.
What you can't search or filter for is "free" and you can't do excludes.
You can also use Google Search in the Gallery and search but it will return results for all watches so you will need to check any items you select to see if it works on your watch.
