11-24-2020 00:51
11-24-2020 00:51
My Sense tracker is not displaying my sleep score on the screen.It displays -- in front of sleep score.
Best Answer11-24-2020 11:53
11-24-2020 11:53
Is this so, even after an hour with a second sync. Sometimes the score doesn't come right away. It depends on the server load.
Best Answer11-27-2020 01:55
11-27-2020 01:55
Its been 5 days and it has never displayed sleep score on the tracker.It just show the details on the dashboard of the fitbit app.Kindly how can this be rectified.
11-27-2020 03:49
11-27-2020 03:49
Do you get sleep scores on the app?
Best Answer11-27-2020 04:07
11-27-2020 04:07
Yes I do get it on the app but it never displays on the tracker ever since I started using it.
Best Answer11-27-2020 04:52
11-27-2020 04:52
Sorry if I'm being a bother, but I'm not able to look over your shoulder.
For sleep score to show, the tracker needs to sync after the user wakes up.
Then the server processes the sleep. It takes a little longer to get a sleep score.
Then the tracker needs to do a second sync. The tracker will only show last night's sleep score.
Try syncing the tracker 10 minutes after getting up. Then sync again after 10 - 15 minutes.
Are you getting the total sleep time on the trackers sleep tile?
When you tap the tile*, do you get the sleep score plus more detail of sleep stages.
*it may take a minute to pull the data from the server.
Best Answer11-28-2020 03:26
11-28-2020 03:26
I haven't tried doing this.Let me try if it works.I really hope this helps !
Best Answer11-28-2020 06:53
11-28-2020 06:53
Same problem. On the app I can see sleep data but on the sense it shows 0 hours of sleep and all stages blank and no score on the watch face even after syncing multiple times.
Best Answer11-28-2020 07:18
11-28-2020 07:18
Ok it is there now. After syncing I had to wait 15 mins then had to open today app on device then it got updated.
