06-09-2022 00:35
06-09-2022 00:35
I noticed it started to loss battery level faster
then yesterday it would not go into exercise mode in gym
so i closed it and it went unstable from that point have tired all the charging resetting not helped
Best Answer06-09-2022 06:16
06-09-2022 06:16
@KarenLeRouz Hello! Did you make sure that Always On Display and Snore Detect aren't on? Those can drain the battery very quickly.
I would also try to sync your Sense and then a complete factory reset on it and remove it from your phone, then start over as if it were a brand new device to see if that helps.
00:35
11:00
06-10-2022
00:35
11:00
Hi @KarenLeRouz - just in case it may now not be charged, check that it is actually charging when you plug in the charge cable, it should show something on the watch or start by itself.
If not, check the cleaning and charge cable, often a problem - see the links and details in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
