06-22-2021 20:25
06-22-2021 20:25
OK, so the latest update provides for press and hold so you can cycle through all your clock faces and change on the fly. Here's the thing -- I press and hold and the only face visible is the current one I'm using. Swiping through, all I see is the written description and an empty box where the face rendering should be. Is this how this is supposed to work? If not, anyone know the/a fix? Thanks.
06-23-2021 22:49
06-23-2021 22:49
Give it time to load the face @Asyd
08:20
08:29
06-24-2021
08:20
08:29
In this new mode of long press, after "Clocks" has appeared, the watch faces with the names appear.It works exactly the same if you scroll left and select Clocks.
Oddly the images don't seem to appear but at least you get the names now [to distinguish between identical looking ones or versions of the face], and scrolling to the next one is now up and down instead of left to right.
Best Answer06-24-2021 09:33
06-24-2021 09:33
How much time? The currently used face is available i'd think a minute or two should suffice for the others, no?
Best Answer06-24-2021 09:35
06-24-2021 09:35
Well yeah, that's the least that could be done, they get the names, but umm, when we looking to choose a face we'd need to see what it looks like -- we don't pick them by name, lol.
