11-01-2020
19:48
17:55
LizzyFitbit
11-01-2020
19:48
17:55
LizzyFitbit
I currently have a FitBit-Ionic running on my Huawei Mate 10 Pro ...
I just bought a FitBit-Sense & I'm about to pre-order an iPhone 12 Pro Max.
Will my past stats on my Ionic come with me when I log in with an iPhone & Sense.?
So the years of data I currently have from my Android & Ionic, "should" sync on the new gear.?
Moderator Edit: Updated label
Best Answer11-01-2020 20:31
11-01-2020 20:31
Yes, as long as you used the same fitbit ID/email. Your data is all stored back on the fitbit computers by your ID/email. As long as you log into the fitbit app with the same ID/email, you can access your data from anywhere.
You should sync from Ionic just before switching to Sense to make sure all your current Ionic data gets back to the fitbit database.
11-01-2020 20:31
11-01-2020 20:31
