What is the difference between the watch time and the actual time (from your phone or computer)? Minutes? Seconds? Can you reply with both values. Also, have you tried other clocks?
Hi @IshaJ the time is derived from the device you used to set up and sync. If you don't sync often, the time can be off. Try syncing a few times and let us know if that worked.
Stepping in the U.S.A. since September 2013. Android 14
