05-04-2017 10:19
05-04-2017 10:19
Hi(:
im 22 F, 5'4 and 164lbs. I started at 196 a year ago so about 30 pounds. I work out a little bit not anything crazy, yet:)
Anyways just a health question. I have a low heart rate normally ... 50's and drops into the upper 40's when lying down for bed but at night my Hr drops to 42:/
i do sometimes get dizzy and SOB. I've had EKGs, blood work and X-ray nothing came back abnormal... but I know and have read that a low heart rate is okay if you're an athlete. I'm not.
I have an apt with a cardiologist next week....
does anyone know If this is normal even if you're not an athlete?? I'm freaking out a bit:/
05-04-2017 10:42
05-04-2017 10:42
And I believe that my low HR at night is causing my RHR to be lower. It's 48 as you can see.... but I thoughts RHR is different than your sleeping HR... so is my RHR actually that low or is my fitbit not calculating it correctly because of my sleeping Hr???
05-05-2017 17:14
05-05-2017 17:14
Aw, don't freak out @SarahLucy145, things will be alright. I'm glad you have an appointment with a doctor, who's advice will be far better than anything I could say.
As to your question about resting heart rate, it's difficult to say. Could you post a screenshot of a 24 hour period, so we can see the high and low periods?
05-05-2017 20:18
05-05-2017 20:18
This is today so far as it's 8pm. I went to my cardiologist and ekg. DIdnt find anything but she's ordering a holter monitor, stress test and echo, to make sure but she mentioned that she didn't see anything abnormal but based on my symptoms she's wanting to make sure.
02-20-2018 18:49
02-20-2018 18:49
Mine does that too! My resting heart rate is usually about 54. When I sleep , it goes as low as 41! I’ve had a 24 hour holter monitor and I was told everything was normal. I have been working out for about 2 years now so I guess my heart is just in good shape? What did your cardiologist say??
02-21-2018 05:30
02-21-2018 05:30
Hey(:
i went and had every test preformed. They couldn’t find anything alarming. She said she didn’t see any sign of heart disease or arrhythmia. She said some people just have a low HR...(:
02-21-2018 06:20
02-21-2018 06:20
oh great! that makes me feel sooooo much better that i am not the only one! 🙂
02-21-2018 07:09
02-21-2018 07:09
A lower heart rate in sleep is normal, and I'm sure I read somewhere that the FitBit RHR is calculated using an average of both sleep and inactive daytime HR... actually yes, I found it -
01-18-2019 09:07
01-18-2019 09:07
Hey me too! I noticed this in 2016 when I got my new fit bit hr and was so scared. I was just sitting there and was in the 40's! I got so scared I couldn't eat and was a new mom so that was bad timing. I don't work out...we do have heart disease in the family, but I am 33 and got all the tests and holter monitors so everything checked out ok! I was told I am healthy and some hrs run low. I noticed I can raise it to a comfortable rate when I have a glass of wine, or anything with alcohol. I have been having one glass of red wine each night and it at least stays mid 40s to 50s now. It also takes the anxiety off of wondering if I'll never wake up lol sounds stupid but it's real. I found out I have a chiari malformation and read that can make your hr low as well. So glad now that new people are using the fitbit hr like you now I see newer posts that are similar! Makes me feel better! I researched this forever lol. Hope all is well!!
07-20-2020 10:16
07-20-2020 10:16
Hi everyone, I got the Fitbit Charge 4 last month & recently looked at my sleeping HR. Mine is low when resting & really low when I’m asleep. This thread has reassured me a little that all is okay though. :). I do have a congenital heart condition, & I’m due to have an appt with my cardiologist in September (whether it’ll be face-to-face or over the phone, I’m not sure at the moment) so I’m going to ask then anyway just to make sure. Thanks for this thread & I hope everyone is healthy heart- & otherwise. 🙂
02-23-2022 23:42
02-23-2022 23:42
I also have a low HR during sleep, low 40’s.
During the day its usually around 58bpm.
I am also wondering if this all started from too much cardio running.
03-05-2022 06:12
03-05-2022 06:12
@H8891 I'm not sure you can do "too much" cardio running, unless it causes an injury. Increasing your fitness level tends to decrease your resting heart rate, which tends to go lower in your sleep. Although my long distance running days are in the past, I still have a resting heart rate in the mid 40's. My lowest sleeping heart rate is 37. I have a Charge 5 and can't use the ECG feature -- you are supposed to be at rest, but your heart rate must be over 50 bpm. But I agree with you, the changes you see are probably due to your increased running.
Laurie | Maryland, USA
03-05-2022 07:33
03-05-2022 07:33
The lowest I've hit this week appears to be 46 BPM. Not too bad. I used to do a good amount of cycling and also worked out 5-6 days a week. Cycling I haven't done in nearly a year and workouts are only 1-3 if I'm luckily but my heart seems to still be pretty efficient when asleep
05-15-2022 18:05
05-15-2022 18:05
If you are dizzy, there is some problem. I generally run a RHR between 40 and 43, but at night I am in the 30s. I know that my heart has slowed a little since I got older (I'm 67), but I have no dizziness. Your cardiologist can determine if your heart is perfusing your brain adequately. Your heart will keep up with your demand for the most part, so don't worry about it too much! I run a little (maybe 6 miles/day) but I'm basically not an athlete, stay healthy and you'll be OK. Good luck!
