01-31-2016 10:15
01-31-2016 10:15
When I use the sleep mode on my Charge my alarms to get up in the morning are silenced? Is there a way to change this?
Best Answer02-01-2016 13:35
02-01-2016 13:35
Are you referring to the silent alarms on the Surge itself?
I typically let the Surge autodetect if I'm sleeping. My silent alarms on my Surge seem unaffected by that. I'll try initiating sleep mode from my iPhone tonight and see if that behaves any differently.
02-01-2016 17:20
02-01-2016 17:20
Best Answer02-03-2016 09:01
02-03-2016 09:01
@daretrace2 wrote:
No. Sorry I should have given more details. My Charge is connected through the Bluetooth on my iPhone and I use alarms on my iPhone to get up in the morning but when I track my sleep with the charge the alarms on my iPhone are silenced.
Sent from Outlook Mobile
I tested last night and no problems. I set the alarm on my phone, then activated the sleep mode through the fitbit app. The alarm went off at the set time, no issue. Sorry I couldn't help you figure this one out. 😕
Best Answer02-03-2016 10:42
02-03-2016 10:42
Best Answer03-09-2016 13:07
03-09-2016 13:07
@daretrace2 did you ever find an answer to this issue you were having? I haven't seen this in the Community before. Thanks so much @Mrthekla for doing some user testing for our friend's issue!
Send over an update if you get a chance, @daretrace2 🙂
Best Answer03-09-2016 13:22
03-09-2016 13:22
Best Answer04-10-2016 22:43 - edited 04-10-2016 22:46
You can check and see if your sleep was logged on your dashboard. If you were still in sleep mode or hadn't entered into sleep mode, there would be no record of it in today's log.
Best Answer07-28-2017 03:34
07-28-2017 03:34
Did anyone find a fix to this? Im having the same problem. My iphone wake up alarms are being redirected to buzz my fitbit when im asleep.
This isnt working cause I dont feel the buzzing fitbit when im sleeping.
