03-13-2016 04:58
03-13-2016 04:58
According to page 21 of the Surge manual I should be able to press the Action button during Free Run activity to manualy apply a split time/lap.
When I first tried this I was surprised that no indication was given that I had pressed the Action/Split button, but it turns out that it's because the feature doesn't work. The manual says: "...press the Action button while you’re running to start a new lap. A summary of the lap you just completed appears for a few seconds.".
Am I doing something wrong or misinterpreting the manual? Could it be that this feature only works if Run Cues are disabled?
Thanks,
Matt
Best Answer04-04-2016 16:26
04-04-2016 16:26
Hello there @mattyboy! Thank you for your question. If you're using the laps option, you need to press the upper right button when you finish the lap and then press it again to start a new one. To get your general information, press the lower right button.
Let me know how it goes.
