Manual entry of activities is obviously already available via the website and apps and data can be imported from other recognised websites. Are you looking for something that isn't already provided by either of these facilities?
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
@cj_burns wrote:
How do you enter steps. I can see where to enter walking or cycling times and distance but I mainly monitor steps with my other non fit bitwatch on weekends Sent from my Windows Phone
@cj_burns The only way to manually entering steps is via the walk or run symbol in the Activity Log. You click on the drop down box and select Steps or Distance. The distance option will convert the distance as steps.
If you select Don't know your Distance, you will only get calories.
It will show up on your Dashboard totals but not on any Groups, leaderboards etc. You will only see the accumulation if you do an activity report in the Activity Log. because your Lifetime Achievements will not show the manual steps.
See how you go.
I use that option for water walking in my Hydrotherapy.
