Alarm not vibrating
Does anyone know how to get the alarm to vibrate
3 REPLIES 3
That is about all it is supposed to do. Did you enable one in the app and then sync it?
How do I do that pkease
Hi there @Fltmadnes, it's nice to have you here! Hello @SunsetRunner thanks for the help! Heart
You can add a Silent Alarm by going to your Fitbit App > Account > Surge > Silent Alarm > Save. Then you will see the information that says "Sync tracker to save Alarms" you can tap on it to sync. Or you can also sync your tracker, by  tapping on "Account" in the Fitbit App, then tap on your "Surge" picture and find the option "Sync now" to force sync. Smiley Happy
If your tracker is not vibrating after this, please restart your Surge and try it again!
I'll be around! Woman LOL
