07-19-2020 01:54
07-19-2020 01:54
I have solved he problem of the bands loosening or separating from the Surge watch by super glue.But the loop that holds the loose end of the band after it is secured has broken several times on two different watches and does not stay together after being glued together. Is there a way to get a replacement for the loops or has anyone found an alternative solution?
Best Answer07-19-2020 09:45
07-19-2020 09:45
Hi @BobR83 going to be hard to find a Surge band replacement, but it's an easy fix. Use one of the silicon hair bands, small size. You can find them at dollar stores in various colors. I used to have them for my Flex and they worked well.
