01-01-2016
13:39
07:16
CindyFitbit
01-01-2016
13:39
07:16
CindyFitbit
Battery on surge not showing full but in mobile app it says it is full
01-01-2016 17:30
01-01-2016 17:30
01-01-2016
23:50
13:14
EdsonFitbit
01-01-2016
23:50
13:14
EdsonFitbit
@Nolander wrote:
The battery meter in the app only shows full, approximately half full, then almost empty. The battery meter on the Surge is more accurate, it has a battery meter more like a phone and drops in small increments.
Ther meter on the app doesn't change from full until you have used at least 1/3 or so of the Surge's battery. I would use the battery meter on the Surge for accuracy and just use the meter on the app as a general guide. I hope this helps.
the battery meter on the Surge can be nearly 0 for 2-3 days before powering down.
not accurate.
Moderator edit: format
01-01-2016 16:10
01-01-2016 16:10
Welcome to the Fitbit Community @mantababe. Please perform a restart to your tracker. If this doesn't work, it could be a good idea turning it off and then back on. To turn your Surge off go to Settings > Shutdown. Let me know how it goes.
Thanks for stopping by, see you around.
01-01-2016 17:30
01-01-2016 17:30
01-01-2016
23:50
13:14
EdsonFitbit
01-01-2016
23:50
13:14
EdsonFitbit
not accurate.
01-02-2016 07:45
01-02-2016 07:45
01-02-2016 08:50 - edited 01-02-2016 08:51
@SunsetRunner wrote:
Ther meter on the app doesn't change from full until you have used at least 1/3 or so of the Surge's battery. I would use the battery meter on the Surge for accuracy and just use the meter on the app as a general guide. I hope this helps.that's a joke.
not accurate.
well tht is most helpful of them isnt it?
thanks by the way
01-11-2016 08:18
01-11-2016 08:18
My fitbit Surge does the same thing and the solution does not work for me. The indicator on the surge shows emtpy but in the app it shows full. I have tried resetting my bluetooth on both devices, restarting my phone and fitbit. Some reason the battery indicator is not synching but everything else is.
01-29-2016 09:12
01-29-2016 09:12
I had same thing as well.
The phone would indicate that it is full when battery indicator in Surge would be 75%.
So it is about 25% difference on the phone (higher) and the Surge (lower).
It is very bothersome.
01-29-2016 11:40
01-29-2016 11:40
Hello everyone. If you haven't done it already, I would recommend setting up your Fitbit trackers as replacement devices. Additionally, you can uninstall and reinstall the app.
Have a nice day.
02-04-2016 12:05
02-04-2016 12:05
02-04-2016 12:21
02-04-2016 12:21
Thanks for joining us @Woodloper. I'm sorry to hear that your brand new Fitbit Surge is not working as intended. In this case it could be a good idea contacting the Support Team. They will be happy to provide assistance as soon as possible.
Keep up the super stepping.
02-04-2016 23:41
02-04-2016 23:41
Thanks, Edson.
After sync'ing three times (that is I closed the app, reopened it...), the battery icon finally did change.
I'm curious about why it takes so long - can you give any insight?
02-05-2016 11:50
02-05-2016 11:50
@Woodloper I'm glad to hear the app is showing the battery level correctly once again. Some other users are experiencing this situation and the engineering team is investigating. For some of them it gets resolved performing the workarounds provided.
Catch you later.
12-14-2016 18:49
12-14-2016 18:49
I can not see the batery charging on the app. Can do you make it show up. Thanks and have a good day.
12-17-2016 06:49
12-17-2016 06:49
Hello, @bulldog2016! Thanks for joinin us! Hmm...what device are you using to sync? I suggest you to log out from the App and log back in. You can also forcequit the App and reboot your device. After this sync again and you should be back on track.
If the issue persists please provide us as much details so we can further assist you.
