12-16-2016
03:54
18:30
EstuardoFitbit
12-16-2016
03:54
18:30
EstuardoFitbit
Hi guys,
Since the beginning of the week in which I made the update of the system IOS 10.2 and the app Fitbit iphone and since then I have had the following problems:
- Syncronize data;
- Clock constantly outdated 30 minutes;
- Excessive battery consumption;
- Slowness in notifications (calls, sms, WA ...);
I've already done Fitbit restart I came up, turned it off and turned on bluetooth ... nothing worked.
Can you help?? Thks!!
Moderator edit: Clarified subject.
It's great to see you participating in our Community, welcome to the Forums @Ricsac84! That's odd you're getting so many issues after updating your iOS to the latest update. Thanks for the details of the steps you tried already. Please try the following steps to see if it help to solve syncing and clock issues:
When your Surge keeps trying to connect with your phone with no luck takes more energy than it should, so if we make it connect properly will stop draining battery. If for some reason the issues with the battery remains please take a look of this tips on how to improve your Surge's battery life. Also remember clean your charger and Surge contacts with a toothbrush once in while. ![]()
Please keep me posted on the resolution! ![]()
