hi
I've had my 'surge' for 5 months.
the last 4 times i've charged it it's stopped charging at around 75% according to the watch battery indicator.
so i unplug the charger and plug it back in and it'll then charge to full.
it's pretty inconvenient having to do this and i wondered if this is a common problem or a faultstarting to develop?
thanks
Welcome to the Community @piedwagtail91! Besides @SunsetRunner's advice, you can also try to clean the golden contacts of your Surge, any dust or dirty may be affecting the connection between your Surge and your charging cable. You can use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
Let me know how it goes!
Thanks for the update @piedwagtail91! I'm glad to know you're back on track! I appreciate your effort on this.
I hope you spend a good time!
