I charged my fitbit completely and when I went to put it on, the screen was black. I know its not off because the back of it still had a green light on it. How do I fix this?
Hey there, @ak55153 and @SunsetRunner! Welcome to the Family! Good to hear that it worked for you @SunsetRunner.
You received some excellent steps to try! If you found them useful let's mark @SteveH's post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you.
You can read more about Accepted Solutions. If you need more help @ak55153 I’ll be more than glad to lend you a hand with that!
Please keep me posted!
Hopefully this is just a software glitch in which case a restart should sort it out:
If that doesn't help then I would suspect a hardware issue and recommend contacting customer support via: contact.fitbit.com
Best AnswerThank you this was very helpful ! Green lights was on & it appeared that is wasn't charging ? I went on here to see if I could find how to turn it off & It was charging Thanks so much works great again!!!!!
