Nice to see that you're digging into the Forums @Srecko, let me give you a warm welcome to our Community. ![]()
Thanks for posting your inquiry here. The blue light is usually related to firmware updates. For this unusual behavior with their Surge's LED, please follow these steps:
1. Make sure you've fully updated your tracker to the latest available firmware.
2. Restart your Surge by holding down the left and bottom-right buttons.
3. Manually sync your device via Fitbit Connect or the Fitbit Mobile App.
If this doesn't solve the battery issues you can also reconnect your Surge with your account by following these steps. Also is important to check these tips to improve the battery life of your Surge.
We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
If this doesn't work please let me know. ![]()
Best AnswerHi,
I belive I have the latest firmware version 16.34.6.1.
I have been through all 3 recommended steps, the blue light is still there ( it only disappears for the time of restarting my Surge by holding down the left and bottom-right buttons )
I am charging my Surge with original USB cable plugged into a USB port of my laptop.
Thank you,
Thanks for stopping getting back @Srecko.
I really appreciate the time you took to troubleshoot this. I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support to the email you used to register with the Community forums.
I'll around in case that you need anything else! ![]()
