05-16-2016 16:41
05-16-2016 16:41
Best Answer05-16-2016 19:27
05-16-2016 19:27
I am having the same problem right now and not sure why either. It's driving me nuts because I am in a couple of different challenges and it says I am at the bottom when I should be more towards the top compared to the other competitors. Possibly a software glitch? My active minutes are also not showing up and I have had plenty of active minutes today. I tried restarting my phone a couple of different times and even uninstalled the app and reinstalled it with no results.
05-16-2016 19:27
Best Answer05-18-2016 13:41
05-18-2016 13:41
I actually fixed this. I ended up deleting my surge through the app then resyncing it. Just poewr your surge off until it tells you on the app to power it back off.
Go into your devices menu on the application.
Select trash can on top right after selection your device.
After device is deleted hit the + sign to add a device and select your device. (before doing this power your device off)
It will take you through the steps as when you firsr bought your watch.
After device is added be sure to log back into your account and hopefully this helps you. Also i have noticed I have checked the option all day sync and always connected. However if you notice the power draining on your device too fast. you might want to disable always connected. Please let me knowif this worked for you like it did for me so we can give people a solution to this glitch.
