03-29-2016 07:22
03-29-2016 07:22
Hi all,
my Surge is set with a 10k steps daily goal.
If I change it to 15k or 20k, does it reflect on device's screen goal too?
The one with the star and vibration you get when you reach the goal.
Thanks for your reply.
Best Answer03-29-2016 09:08
03-29-2016 09:08
Yes I can confirm that the screen will change to what ever you set your new goal at. But it will need to sync before it takes effect.
Wendy | CA | Moto G6 Android
03-29-2016 07:35
03-29-2016 07:35
Yes, but you'll have to sync before those changes take effect.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer03-29-2016 07:35
03-29-2016 07:35
Hover your mouse over the bottom of the today goal over to the Left. When you see the gear click on it and you will see where to change the goals.
Happy Stepping!
Best Answer03-29-2016 07:43
03-29-2016 08:47
03-29-2016 08:47
Yes, I believe that's the way it's intended to work, though I haven't changed my step goal. @WendyB, can you confirm?
03-29-2016 09:08
03-29-2016 09:11
03-29-2016 09:19
03-29-2016 09:19
Thanks! I've been meaning to change mine to 13,699 steps. No time like the present. Just did. ![]()
I most days I wear the one when I get my goal, so I will rarely see that notification.
