01-08-2016 14:11
01-08-2016 14:11
Best Answer01-08-2016 15:41
01-08-2016 15:41
Does it do so when its plugged in and charging? Do you have notifications turned on in your fitbit settings?
Best Answer01-08-2016 15:51
01-08-2016 15:51
Best Answer01-08-2016 16:32
01-08-2016 16:32
I've noticed with my surge that when I have it plugged in and charging, it makes an initial vibration to indicate that it's charing but the plug seats awkwardly in the power slot for the surge. I believe (and I could be wrong) this causes it to constantly register as *Connect-Disconnect-Connect* while charging, therefore causing the surge to constantly vibrate.
If this isn't the problem, also check into seeing if you have any alarms set on your surge that you haven't disabled.
Best Answer01-08-2016 16:57
01-08-2016 16:57
Best Answer01-09-2016 13:05
01-09-2016 13:05
Well sorry to say, but that's where my knowledge dips off.
Best Answer03-29-2016 07:28
03-29-2016 07:28
I have the same problem with my Surge. You can sometimes stop the vibration by moving or pressing the bracelet. I think it must be a broken or intermittent contact inside the watch as it responds this way.
