Best AnswerWhen ypu say that you told the phone to forget the device, this was done through the phones Bluetooth screen?
A normal sync through the app, should reconnect it,
My suggestion would be the 2 button reset, turn the Blaze off through its settings menu. Then a restart of the phone, better yet a complete shutoff of the phone.
The Surge does not have the ability to do a factory reset, which would then require a complete setup of the Surge as a replacement device.
The time time is off because it hasnt synced recently.
Best AnswerThere is 2 types of restarts that can be done on tje Surge, a hard restart by holding the left and right button simultaneously for 15 seconds, now wait for the display to turn off. Now press a buttun to turn it on.
The other way is to go into the sertings menu on the Surge and do a shutdown. Neither one is a factory reset that would erase everything on the Surge and require setting it up as a replacement device. But i csn assure you that there is not a factory reset for the Surge.
Hints to fix would be to try both types of restarts, restart the phone, add the Surge as a replacement unit. Turn off the Bluetooth of any nearby device that Surge has ever synced through. Check the tips in the help document, http://help.fitbit.com/articles/en_US/Help_article/1866/
Edit the title of the post to reflect that you have an iOS device, which would make it easier to get answers from iOS users.
