08-27-2016 20:14
08-27-2016 20:14
I had my first fitbit surge back in Feb 2015. At that time I wore it everyday as a regular watch, and used the GPS and heart rate monitor to track my runnings. After about 6 months, the clear heart rate sensor screen cracked, and my watch stopped working after a couple of days. I contacted Fitbit and they sent me a new Fitbig surge. I suspected the same thing would happen to my new surge so I only wore it during my run instead of all the time, hoping to make my watch last longer. Sure enough, now after about 1 year, the screen cracked again and the watch started to act up. It lost all the charges in less than 12 hours after I fully charged it. Something happened similar to the first watch I got before it died. Does anybody else has similar issue with their Fitbit surge? I am surprised I don't see more people complained about the problem I had. I took good care of the watch by cleaning it after every run to clean up the sweat. Did I clean it too much?
08-28-2016 09:28
08-28-2016 09:28
@wms2015 Welcome to the Fitbit Community! That is very strange, never heard of that before! Maybe you were cleaning it too hard? It is recommended to use a soft swipe to gently clean the sensor if needed. What method were you using to clean it up?
Keep me posted!
Best Answer09-06-2016 07:51
09-06-2016 07:51
I usually wet my hand with water, sometimes with mild hand soup, and wipe across the top and bottom of the watch, as well as the wrist band. Then I just pat dry it with a soft hand towel. I know I am not cleaning it with anything hard.
Best Answer09-08-2016 06:23 - edited 09-08-2016 06:23
Thanks for the information @wms2015. In this case, about the broken part, I recommend getting in touch with our support team, I know they will have a solution for you. About the battery inconvenience, I recommend doing the following:
To maximize your tracker's battery life:
After the tips to maximize your tracker's battery life try these steps:
1. Dirty charging contacts.
2. Try a different USB port or UL-certified wall charger. Do not use a USB hub.
3. Try reconnecting your tracker to the charging cable.
Now, if none of these steps work, again feel free to contact support. For a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
07-25-2017 08:09 - edited 07-25-2017 08:10
I just had the same issue and it is the second time it happened. The first time it happened was about 6 months after I got my first Fitbit Blaze. Fitbit sent me a new one and now about 8-9 months later I'm having the same issue, the HR screen is cracked and no longer registering my HR. I use a slightly damp wash cloth with warm water to clean it. Fitbit, please help. Thank you!
