Run option has disappeared from fitbit surge quick access. On app and desktop settings it appears to be still at the top of the list. I want it to display as before so I can track my distance and pace and the map generates on the app later.
Best AnswerThere should be a separate "Run" menu if you swipe to the right from "Exercise". Under this, there should be "Free Run", "Treadmill Run", and "Lap Run". Strangely enough, I'm having the opposite issue now. I just changed my Exercise Shortcuts, and now "Run" appears under "Exercise", and can't be deleted or moved via the Android App.
