My first fitbit was awesome for customizing my workouts. I had 2 weight lifting routines that I had programmed the number of sets per exercise with 1 minute rest periods between sets and 2 minute rest periods between exercises. I also had a running program that I was able to set a 20 minute run broken down into 1 minute intervals of various intensities. The only reason I got a new fitbit was because the band broke and it would no longer charge. I figured the surge was a step up but now I see no place I can use the same programs I had established with my first fitbit. Any suggestions??
Best AnswerHello @Joeseabee I'm not sure what Fitbit you had a but the Surge should have the options your old Fitbit had
Have you added without them checked the weightlifting settings for the options?
How do I track my workouts with my Fitbit device?
