Hey there, @FILIPPOS! Welcome abord!
At the moment there is not. However there are a lot of cool Apps and products that are compatible, check them out!
I hope this helps, let me know!
Dear SolangeFitbit
I cannot say that I am happy with the answer as it is advertised as a cycling watch as well. The cycling community knows that cadence is required among the other features. I believe it would have been very easy to upgrade the software and make it compatible with so many cadence sensors available in the market in order to close this gap. Then it would have been a real value for money gadget.
The solution you suggested, although I do not think it offers this feature I am asking for, involves other equipment like carrying your mobile with you etc.
Hello, @FILIPPOS! Thanks for your answer and feedback. This is very important to us to add new features in the future and improve in every way possible. Also, I invite you to post your ideas on this section so our developers can check them out!
See you around. ![]()
Best AnswerI would look to get one that is compatible with your phone and sync that with Strava. For cycling, I wind up using my old Zip along with my Surge because the Surge does a lousy job of converting pedaling into steps. I clip the Zip to my shoe. Still not cadence but better step counts.
