05-10-2016 11:10
05-10-2016 11:10
I've had my Surge for 3 weeks now and enjoy all the fitness features. One thing I've noticed is that the Calorie Count seems way off when I cycle outdoors. I rode 40 hilly miles on Saturday at a 15mph+ pace. My Surge said I had burned 600 calories(about the same as an one hour hike) for the entiire ride. My Cyclemeter App stated I had burned 2300 calories(probably a little high).
Has anyone else noticed this issue?
Best Answer05-24-2016 11:51
05-24-2016 11:51
Hello @Adkduffer, welcome aboard to our community. Note that your calories will be determine by the intensity of your exercise and if you have a tracker with Heart rate sensor like the Surge, then your calories will be more accurate as it will read the BPM to determine your calories rate. Having this in consideration I don't think your calories are overcounted.
For more information, please take a look at the explanation of this post. I like to recommend this post from @SebringDon, when it comes about calories burned.
Hope this information helps, see ya later my friend.
Best Answer05-25-2016 01:21
05-25-2016 01:21
The good thing with the Surge while exercising is that since the HR reads 40 or 50 beats under on a bike ride (Polar 150 average, Surge 100) the actual calories you burn will be much higher than recorded, so a great result if after that you still achieve your daily goal ! At least thats the way I try and look at it....
