08-14-2017 13:02
08-14-2017 13:02
My Fitbit is measuring the distance on the unit itself but when I download the data onto my IPad , the distance recorded is much less. I did 32miles on the bike but the record only showed 4 miles???
Is something not set correctly ?or is it faulty
08-19-2017 12:20 - edited 08-19-2017 13:22
Thanks for joining this family @DaveEllson, hope you like what find here! ![]()
Thanks for posting your questions on the Forums! I'd like to know how you're tracking your Bike activities, as it might be that we need to check some setting or you might just restart your Surge to get the correct information. If you're using the GPS feature it might be having a hard time connecting with the satellite, you can read more about it here. If you can include screenshots of the information you got, that will help to determine what happened with your Fitbit.
Hope to see your next answer soon! ![]()
08-19-2017 15:56
08-19-2017 15:56
