10-02-2016 23:57
10-02-2016 23:57
Best Answer10-03-2016 08:55
10-03-2016 08:55
There is no setting for that. Your tracker is getting the info from whatever device you are syncing with.
Best Answer10-03-2016 11:20
10-03-2016 11:20
10-03-2016 15:56
10-03-2016 15:56
11-13-2016 08:11
11-13-2016 08:11
@Gibbo086 @Biilbo Welcome to our Community! This is odd, make sure that both your phone's and your Fitbit app (menu button, account, gear icon, Time zone on Android and on iPhone Account, Advanced settings, Time Zone) are set to Automatic time zone in their respective settings area. After this sync your tracker. You can also try logging out from the app and restart your phone, then log back in a sync your trackers again. Finally if this doesn't work manually change the time zone to one that is correct so your tracker will display the correct time.
Let me know how it goes!
