When it gets wet like that You should put it in a bowl of rice for a few days to take out the Moisture
I would go with what support said.
Wendy | CA | Moto G6 Android
It's nice to see you around the Community @Petdr954
! I'm so sorry to hear what happened to your Surge my friend.
Did you try @WendyB's suggestion? Please place your tracker into a bowl of dry rice for 24 hours. This will extract any moisture that remains inside the unit. Following this, please attempt to restart your tracker using @SunsetRunner' steps.
Hope that helps, keep us posted!
Thanks for trying my friend @Petdr954! My best recommendation would be to get in touch with Customer Support directly.
They'll be more than glad to give you a hand on this, don't forget to mention all the steps you've done so far and also don't forget to check the warranty policy.
Have a nice day!
