12-04-2016 08:09
12-04-2016 08:09
My Fitbit surge is not displaying the correct amount of steps, calories burned, and miles but when I sync it to the app on my phone it shows the correct numbers on my app. I tried restarting it but it did not work. Any suggestions?
Best Answer12-05-2016 23:05
12-05-2016 23:05
If restarting did not hep then I would Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
Best Answer12-06-2016 07:43 - edited 12-08-2016 08:06
Hope you’re having a great day @Kathenry17 and welcome to the Forums! If you already tried the restart and your tracker is currently syncing but is still not showing the correct information. Are you logging any activity? When it started happening? Have you done anything different?
As @WendyB mentioned, it's best to contact Customer Support . I'm sure they will be glad to assist you with this! ![]()
Give it a shot and let me know if that works! ![]()
PS. Great participation @WendyB, you're always in the right place at the right time! ![]()
Moderator edit: Clarified subject.
