07-14-2016 19:28
07-14-2016 19:28
Best Answer07-15-2016 04:36
07-15-2016 04:36
Hi, it is a bit of a mystery. As you know your resting metabolic rate is probably around 2000, mine is 1760 as I'm a bit lighter than you. So that accounts for that without moving. HR certainly affects the calculation but it is still a guess - but it shouldnt be a million miles out even accounting for different levels of fitness between people of similar age, height and weight. And actually when I do a bike ride as I did today, I also wear a chest strap using an app on the phone - the polar app and surge recorded within 50 calories of each other over 1300 burnt, that is not bad, the difference being surge isnt quite as consistent on recording the heart rate, but suggests both are in the ball park.
I target 3000 a day calorie burn and that is generally a 25-30 mile bike ride and 5- 10 miles walking to achieve that including of course RMR. I generally will burn 3500 on a typical day with that activity level.
Curiously though, even though I am logging food and consume about 2000 my weight has been static at 185lb for a month having lost 10lbs in the previous month....nope, I dont know why either!!
Not sure if this helps you but its my take on my own experience.
Best Answer07-15-2016 15:00
07-15-2016 15:00
Best Answer07-19-2016 23:54
07-19-2016 23:54
Best Answer08-14-2016 16:24
08-14-2016 16:24
@Jbone & @Martian69 welcome to the forums! @Chris1963 pretty good insights my friend.
Please keep in mind that your trackers calculate your calories burned based on your basal metabolic rate (BMR) which is the rate at which you burn calories at rest just to maintain vital body functions like breathing, heartbeat, and brain activity. our BMR usually accounts for at least half of the calories you burn in a day and is estimated based on the physical data you entered when you set up your account: gender, age, height, and weight; double check if that info is correct for the calories to be counted more accurately.
Also, the calorie burn estimate that Fitbit provides takes into account your BMR, the activity recorded by your tracker, and any activities you log manually. Now, if you wear your tracker while cycling then use the bike exercise on your Surge to track it and see how it contributes to your daily calories burn. Just like you guys were discussing the fat burn zone definitely causes a higher percentage of calories are burned from fat, but the total calorie burn rate is lower.
Hope this info helps. Catch you later! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
