I have just got a surge and everything has set up fine. I have followed all the instructions and looked at the community about exercise shortcuts but when I go to my settings this option doesn't come up? Any advice?
Thanks
Rachel
Are you using the Android App, @Rstokes11? If so, go to Account, select the Device, and scroll down the page to Exercise Shortcuts.
A warm welcome to the Fitbit Community @Rstokes11! As @USAF-Larry suggested you can go to your Fitbit.com Dashboard on your Computer or the browser on your phone. In the upper right corner of your Dashboard you will find the "Settings" > Tap on Surge .
Once you have found the "Exercise Shortcuts" choose the ones that you want and "Sync" your Fitbit. ![]()
Hope this helps, I'll be around in case you need more help! ![]()
Hey there @downing, I hope you're doing great! Your Surge has the SmartTrack option to track Outdoor Bike, you will find the information in the Settings too. SmartTrack automatically recognizes workouts or activities where there is continuous movement. You can change the recognition time to 10 min, so your Fitbit should be able to automatically determine when you're biking outside. ![]()
Hope this works, have a great day! ![]()
