01-31-2017 18:04
01-31-2017 18:04
I recently was handed down a fitbit Surge, it is nice but the problem is, that it has a broken strap. I have seen many videos of people ordering from off of a website called Alexpress. This method seems to work and since it is handed down the waranty would not be valid so this seems to be my only option. The question is, It came with a large strap but my wrist is small so If I order a small band from Alexpress will it fit the Surge?
01-31-2017 23:22
01-31-2017 23:22
you will need to ask Alexpress to get your answer.
Wendy | CA | Moto G6 Android
02-01-2017 04:28 - edited 02-01-2017 09:48
Welcome to the Forums @IzakFit! It's great to see you here. I'm not familiar with the options that Aliexpress has, but it looks like a good idea on paper. As @WendyB said, you might need to do some research first. You can also contact Customer Support, just to see what are your options as you are a new Fitbitter now! I think that it's best to try all the possible options that you might have.
Have a good one! ![]()
