10-28-2017 08:55
10-28-2017 08:55
Hi Everyone,
Am unable to sync my Surge through Bluetooth, since I updated my Fitbit mobile app yesterday.
Is anyone else having trouble syncing their device after the latest software update.
However, am able to sync the data through the USB cable.
Best Answer10-29-2017 08:19
10-29-2017 08:19
Are you using the Android app? A few people are having the same issue.
Best Answer10-29-2017 21:02
10-29-2017 21:02
I have not been able to sync my Fitbit Surge with my Samsung S5 Android phone since 27th September 2017, because since then I have needed a password to log in and had not set one up during the setup process. Passwords I tried didn't work, but I finally found one that worked today. Unfortunately when trying to sync, to the Surge it goes through the rotating image routine but stops with a red exclamation mark.
The firmware version I'm using is 16.34.5.14. Any advice please?
Best Answer10-29-2017 21:27
10-29-2017 21:27
Mine too, is not connecting with blue tooth both pc and mobile.
Best Answer10-29-2017 23:27
10-29-2017 23:27
You are facing this issue after recent update right ?
Do let me know in case you come with a solution for this !
Best Answer10-29-2017 23:32
10-29-2017 23:32
Hi Rishi,
Did you also try removing you device and pairing it again?
Best Answer10-30-2017 00:49
10-30-2017 00:49
I even called their customer care. They are saying that case is under review.
Best Answer09-13-2019 23:49
09-13-2019 23:49
After recent update my surge is not syncing automatically everytime I have to uninstall the app and reinstall and repeat the process again .Even I have downloaded older version what the problem is not solved..Please help.
09-13-2019 23:51
09-13-2019 23:51
After recent update my surge is not syncing automatically everytime I have to uninstall the app and reinstall and repeat the process again .Even I have downloaded older version what the problem is not solved..Please help..l am using OnePlus 6 T
Best Answer09-16-2019 06:40
09-16-2019 06:40
Since getting the latest software update My surge has also had problems linking with my android phone and as of Saturday night it has stopped syncing altogether. Has anyone found what the issue is yet? Is there a way to rollback to the old version that worked?
Best Answer09-20-2019 22:24
09-20-2019 22:24
You can check out some things. I wrote a post about:
Best Answer10-01-2019 17:12 - edited 10-02-2019 09:27
Here's how I fixed sync issues with my LG V35:
If Surge shows as "Paired" in the BlueTooth screen on your phone, un-pair it, turn off BT and restart phone. Restart Surge. In Settings on the Surge, turn on BT Classic to "pair" and turn on phone BT. You should get a 5 or 6 digit number on the Surge that matches the BT screen on the phone. Click OK if needed, then turn off the phone BT again. Then start the Fitbit app and navigate to set up new device. The software will ask permission to turn on BT, click yes. Then you'll get the 4-Digit number on the Surge to type into the app. The rest of the setup completed without delay and it's worked for the rest of the day, capturing steps and heart rate.
